93 3VZE timing belt replacement
Old May 28, 2017 | 03:23 PM
Cstandley@5799's Avatar
I replaced the timing belt, water pump, valve cover gaskets, plugs, wires, cap rotor and I take gasket on my buddies 93 pickup with a 3VZE. It started right up and ran for 5 minutes then died. I have checked all fuses, relays, hoses. It's getting fire and fuel but won't start. Any one else have this problem?
Old May 28, 2017 | 08:36 PM
thook's Avatar
you're sure it's getting fire AND fuel? how'd you check?
how'd it run when it was running?
ground wire on the injector harness reattached? afm connector is positively seated well? all sensors on the cluster back of the motor connected well? (mainly coolant temp switch)
any CEL codes, or just consistent flashing?
