92 Yota Help
92 Yota Help
Hello everyone,
My name is Nelson, and I’m hoping this community can help point me toward the right mechanic or shop for a proper restoration of my 1992 Toyota Pickup.
Truck details:
Background (condensed):
So now I’m turning to the people who actually know and appreciate these trucks.
…I would sincerely appreciate the guidance.
This truck has been part of my life for decades, and I want to do right by it.
Thank you,
Nelson
Truck details:
- 1992 Toyota Pickup, 3VZ-E V6, 5-speed manual, 4x4, Extended cab, Owned for over 20 years
- Head gasket replaced in 2015, Only ~100 miles driven afterward before long-term storage, Cold start issues traced to a broken cold start injector and damaged wiring (now repaired, however it is doing the same thing as before, taking at least 5 minutes to start up, especially in winter. I was previously told one cylinder had low/no compression, but performance has improved with use. I was also told that because it only had less than 100 miles on it after the head gasket repair, that something might not have seated right, and with use, it would get better? I did replace the knock sensor in it as well. Still noticing a raw fuel odor when driving that I want properly diagnosed
What I’m looking for:
- A shop or individual experienced with pre-OBDII Toyotas, Familiarity with the 3VZ-E platform, willing to take on this project and located in or within a few hours of Springfield, Missouri (happy to travel)
Thank you,
Nelson
Raw fuel you say?
like a leaking line somewhere? The symptoms you give are that of a faulty cold start injector. I understand it was replaced, but maybe the reason it failed is still present?
as for the head gasket, so you can have the most information, if I were you, I’d go get a compression check gauge and just get the compression on each cylinder.
the cold start injector being bad can give excess fuel
smell but it can create high carbon symptoms and cost the plugs, also making starts hard and poor driving.
when you replaced the cold start injector did you pay any attention to the thermo switch (ctts). That can make the injector not work or work too much, making the environment rich.
Thank you K9Kodi! With my limited knowledge, I tested the cold start injector. I unbolted it and turned the key and it shot fuel out. I did this after I replaced the cold start sensor and fixed the short in the wire........Self admitted, I don't want to dig too deep, I am afraid I will mess something up.
Innova Scanners
Apr 3, 2025 02:59 PM
PatchworkPatty
10
Nov 8, 2024 07:41 PM
