91 yota pickup v6 coolant leaking
Old Mar 17, 2014 | 05:29 PM
tfred1313's Avatar
Ok I have a v6 pickup, ive replaced the water pump cause I had coolant leaking out the front. got everything back together and still had leaking. ok I said maybe I messed the gasket up, do it all over. ive taken it off and put it back 4 more times now. im starting to think its something else, I don't think I can fail 5 times at this. does anyone have any ideas on what else is could be.
all I can give you is that coolant is coming from the front of the engine right when it gets warm. I drips a little bit if that when cold but when it warms up is starts to pore. head gasket maybe? idk. ideas please. thanks
Old Mar 17, 2014 | 05:36 PM
Innocent Fool's Avatar
Cracked thermostat housing?
Old Mar 17, 2014 | 05:44 PM
tfred1313's Avatar
no i can see that its coming from the other side. i thought that to and inspected it.
Old Mar 17, 2014 | 06:04 PM
tfred1313's Avatar
maybe its the timing idler that sits between the cams? anyone know of that being a issue?
kawazx636
Oct 6, 2021 03:03 PM
ladybugRC
458
Aug 21, 2020 10:41 AM
LittleUgly
15
Jan 2, 2020 01:30 PM
Ditch Doc
Oct 27, 2015 03:20 PM
kcaudill
Oct 10, 2015 02:39 PM
