87' 22RE Horrible idle surge, throttle useless.
Old May 11, 2012 | 06:46 AM
defrag4's Avatar
I brought my truck into a mechanic with what i assumed was a bad TPS. I had no power above 3K RPM, I did a sweep-test with my OHM Meter and found the TPS had a deadspot. Not having any luck finding a new TPS down here in Costa Rica I figured the mechanic would have better resources.
When I brought the truck in it was still drivable. The mechanic putzed around with my truck for 2 weeks until I finally got fed up, headed down there and limped it out of his shop with the same busted TPS, but now in much worse condition than when I dropped it off.
Now its idle is all screwed up, It sweeps from 7K to 2K over and over and over. Messing with the throttle does nothing, I cant rev it, cant do anything. When I remove the TPS cable from the TPS it goes ape and redlines.
I can limp it around with the tach sweeping from 7K to 2K, bucking and chucking the whole drive.
I adjusted the TPS but that made no change, I assume the TPS is pretty much dead now but there must be some other issue at this point.
I found a crack in the air intake hose to the TB and fixed it up with some ducttape. Made no change. Checked for vacuum leaks but found none. I am wondering if maybe he hooked up some vac lines wrong. Need to check them all again.
Any ideas? Here is a video.
22RE IDLE SURGE TPS - YouTube
Old May 16, 2012 | 05:25 AM
defrag4's Avatar
Turned out to be a kinked line in the fuel pump, had to drop the tank to find out.
smthwsn357
May 1, 2024 07:28 AM
montanatruck
Feb 26, 2017 07:07 AM
Alex Bessinger
Aug 31, 2015 09:17 AM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
kcaudill
Jul 20, 2015 12:06 PM
