86 turbo coolant leak issue
Gentlemen and ladies of yotatech,
Here's the skinny: I found a coolant leak at my thermostat inlet about a week ago and replaced the thermostat with a 180 degree rating and installed a new gasket/o ring. I replaced the radiator cap with a 13 psi rating as well. This was all done yesterday. I refilled the system but, in hindsight, I didn't burp the air out. Anyway, I drove my truck yesterday and saw that the engine threatened to overheat a couple times but hasn't yet. I felt the upper rad hose and could tell that water was flowing. However, when I shut off the engine coolant starts spewing from the rad side of the upper hose. I'm wondering if air in the system could cause a leak?? The hoses are all new and the clamps are secure. Any suggestions? Thanks!
Air would give it more room since air compresses better than water. Air in the system would give a false overheating gauge though.
Sounds like you have some sort of blockage. Are you sure the thermostat is the correct one and installed correctly? Did it happen to have a seep hole in the middle to allow coolant through when cold? I've heard that can help the issue some to prevent too much pressure building upstream.
Try putting the old rad cap on and see if it fixes it. The new one you bought may not be at the right pressure setting as the old (not sure if it's different on a 22RET).
Lastly... have you ever put any kind of additive or "sealant" in your coolant to fix a leak? If you have... well...
jasonty
41
Dec 23, 2018 01:00 PM
Poncho0206
Jul 10, 2015 06:21 PM
Avenged
Jul 9, 2015 07:55 AM
