86 22rte bad head???
Subscribe
Nov 6, 2011 | 10:02 AM
well i bought my 86 22rte about three weeks ago with a rebuilt engine. there were many things on this that were nig rigged beyond belief (should see the exhaust). so driving it, and it got pretty warm and died, not up to red. compression is well not good. 60,~5,40,60. no coolant in oil, and no oil in coolant. also when turning over w/out plugs to get some coolant out of the cylinders #4 continuosly dumps coolant.
Plan at this point is to pull head.
uncle josh is a mechanic and thinks it is the head, but me not having as much experience figured i would see what you guys had to say.
thanks,
Mike
Reply 0
Nov 6, 2011 | 02:36 PM
It's probably a cracked head, my 22rte was cracked between the exhaust and intake valves of #4 as well. With the larger compression chamber (83 cc.) than the 22re head (54cc.) there is less metal between the valve seats and these heads are prone to cracking. It's pretty common. Sounds like yours has a crack into a water jacket.
Reply 0
Nov 6, 2011 | 04:12 PM
Ok cool thanks alot. I'm going to be pulling the head here this week. Thanks so much, I'm glad to have joined the yotatech community all of you guys are so helpful!!
Reply 0
Nov 18, 2011 | 04:19 PM
Wow! Didn't know they were prone to cracking, from the research i did saw these are very prone to head gasket failure. What causes the head to crack? just that it is thin? Are the cracks in the head repairable or new head?
Reply 0
Nov 18, 2011 | 04:25 PM
New head! 22Re heads work pretty well on these with the stock low compression pistons.
Reply 0
Nov 18, 2011 | 09:00 PM
Oh ok thanks for the advice good to know. Is there a difference in the 22re head Vs. The RTE?
Reply 0
Nov 19, 2011 | 02:32 AM
Depending on who you ask and what website you access the Rte has either a 63cc or an 83cc combustion chamber. The Re has a 53 or a 58cc combustion chamber. These are the numbers I've seen.
Reply 0
Nov 19, 2011 | 08:02 AM
Alrighty so can just put a regualar 22re head on it and go good to know thanks again
Reply 0
