3VZE oil filter seal keeps blowing
I just rebuilt my 3.0 in my girlfriends pickup. She drove it for about a week with no issues but now, all of the sudden, it puked all the oil out of the oil filter gasket. So, I put on a new filter and it did it again. Where is the oil pressure relief valve on this thing? Would that cause a problem such as this. There is an allen head plug on the oil pump housing kind of in front of the oil filter. I pulled that out thinking it was the valve but the chamber was empty. Any advice?
It's in the bottom of the oil pump housing.
http://personal.utulsa.edu/~nathan-b...118oilpump.pdf
I don't know, maybe it would? Could also be there's some kind of restriction/blockage in the oil passage(s) after the filter causing excessive pressure. Or possibly a combination of both.
http://personal.utulsa.edu/~nathan-b...14operatio.pdf
Quite a bit actually. 36-75 PSI @ 3000 RPM
http://personal.utulsa.edu/~nathan-b...16oilpress.pdf
jasonty
41
Dec 23, 2018 01:00 PM
88yodabasket
Jul 13, 2015 01:32 PM
