3vz-e timing probs!! pullin my hair out here
Old May 16, 2010 | 05:41 PM
Phatboy1048's Avatar
Question 3vz-e timing probs!! pullin my hair out here
ok just did heads on my 3.slow and got everything back together everything was great but i cant get the damn timing to get on 10 degrees btdc the heads are new cast complete with cams from clearwater cylinder heads. distributor wont line up where the hold down bolt went without the rotor not bieng correctly on top. um im going to check for vaccumm leaks tomororw bt i dont think it has any all vac hoses ok and in the right place. i did jump the ecu makng sure it wasent interfering with the timing. anybody? got a clue wth is goin on?. it runs... drove it back from my shop thinkin bout drivin it off a cliff and getting insurance money hahah jk.. thanks you all.
Old May 16, 2010 | 06:39 PM
bugs1961's Avatar
Sounds like it's running so the distributor isn't 180 out. My guess is you have it a tooth off on the cam gear. Try pulling it out again, noting where the rotor is when the dist. just separates from the cam gear. Then rotate the rotor a little in the correct direction to fix your problem, while lightly pushing in, until the distributor falls in on a different tooth position.
Old May 16, 2010 | 06:41 PM
yea ive tried that like 8 times already haha going back and forth idk wth is goin on. it feels like a big jump in teeth but i go back and try it again bu its just the same thing.
Old May 16, 2010 | 06:52 PM
bugs1961's Avatar
Yea, that's strange. The only other thing I can think of is a gear that's gotten damaged and is no longer in the correct place or the rotor alignment key is broken and the rotor is rotated on the shaft. If you have access to another dist. I'd try to install that one and see what happens.
Old May 16, 2010 | 06:54 PM
um rotor key is okand as far as the gear idk. ill pullit out tomorrow and look at it just kinda bummed my trucks been sitting awhile and now this.. damnn
Colington
Mar 8, 2020 09:51 AM
Eggslinger
Jun 8, 2019 03:32 PM
Sep 4, 2015 09:27 AM
smiley52
Jul 11, 2015 05:16 AM
