3 Inch Body Lift Automatic
Old May 23, 2012 | 04:15 PM
Fierce Legend's Avatar
I just installed the blocks. The intruction manual says to cut, ;engthen and weld the shifter linkage or somthing of that sort.
Here a picture and maybe you guys can tell me what I need to cut and weld for the transmission and transfercase.
maybe you could photoshop it and show me were to cut and how much metal to put inbetween I thinki I can figure out teh rest for welding it back together.
Last edited by dropzone; May 23, 2012 at 05:39 PM. Reason: changed pic code to [img] better that a link
Old May 23, 2012 | 04:22 PM
waskillywabbit's Avatar
Try asking the company that sent your instructions.
:wabbit2:
Old May 23, 2012 | 08:10 PM
BigSwole's Avatar
I have a 1990 auto. I ordered the a/t brackets fron 4crawler.
NEVER used it. I have a 3" bl on mine and it all works the same.
I just lifted it and it works, so if it aint broke dont fix it.
Old May 23, 2012 | 08:42 PM
That linkge peace for the transfercase is hitting the rear driveshaft as you can see the oval part is supposed to be down more. The transmisson shfter works fine. Taking it out of park you gotta push forward a little and then back I dont think ill change that.
For the transfercase im going to make a spacer from the floor to that mount eith teh pivot and everything should work just fine.
Old May 23, 2012 | 08:47 PM
justin_4runner's Avatar
the two bolts that are holding that part up... looses and put some spacers in there and then rebolt it, see what that does, just an idea....
Old May 28, 2012 | 09:02 PM
Oldscooltoys's Avatar
I'm bout to lift my 94 4runner but all I they sold me was what looks to be a spacer for the linkage on the transfer case or for the transfer case do I need an extension for the shifter for the trans? Does anyone know???
Old May 29, 2012 | 08:51 AM
yotarover's Avatar
Made my own 2"bl out of 2" solid high grade alum. Didn't need to lengthen anything. Left the rubber stock pieces on the mounts then added mine, so it's about 2 1/2 maybe a lil more. No issues
Flying91
45
Apr 11, 2024 04:39 PM
Sep 4, 2015 09:27 AM
coffey50
Jul 28, 2015 10:55 AM
Michael oaks
Jul 27, 2015 11:47 AM
akaphilly
Jul 9, 2015 02:18 PM
