3.0 engine mount question
Old Dec 11, 2017 | 04:21 PM
Knix47's Avatar
So I'm in the middle of reinstalling my rebuilt 3.0 in my 92 4Runner on new engine mounts from LCEngineering. I'm having issues lining the engine mounts up to fit. I'm wondering if the sides that bolt to the frame (side that holds the rubber) are different and I have them on the wrong side and that's why it doesn't want to line up correctly. Has anybody had an issue like this before or could provide some insight on my problem? Thanks!
Old Dec 11, 2017 | 05:09 PM
dropzone's Avatar
Fossilized
there should be alignment hole or tabs
thought they were the same but this old post might help
Originally Posted by Ganoid
Maybe this will help...
Attachment 192627
Attachment 192628
I wil go check the late 80's 3.0 I have on the stand out in the garage later and see if it has the same mounting situation as the block you have.
Old Dec 11, 2017 | 05:18 PM
Knix47's Avatar
That's what I thought too. But on my passenger side it only fits with the hose bracket on top but then the bolts that attach it to the fram don't want to fit. I just figure I would ask here before I lift the engine and have the switch them around.
Old Dec 12, 2017 | 04:12 AM
wyoming9's Avatar
Red face
No Telling what LCE might have done !!
Did they send any Instructions ??
According to Napa the engine side mounts are the same part #
I Don`t have a block to see if it is possible to get them on upside down .
You have them bolted to the block as you drop the engine in.
It is almost impossible trying to bolt them to the block any other way
Batsoff
Nov 29, 2008 11:30 AM
Corey
Sep 25, 2006 01:37 PM
byron4
May 18, 2006 04:39 PM
transalper
10
Jan 17, 2003 12:09 PM
