22rte wont idle (vacuum related)
Old Jun 1, 2012 | 12:12 PM
matthew22r's Avatar
I know its vacuum related because the truck ran until I was messing around with the vacuum connections. I was hooking up an external wastegate but I had put the vacuum lines on the wrong side of the throttle plate (after) and then truck wouldn't idle, I reverted back to the working configuration and the truck still wouldn't idle. Now it doesn't seem to regulate vacuum correctly. If I cause a vacuum leak by unhooking any random vac hose, the truck will idle but I have no throttle control. It will sustain an idle but I cannot control the revs. I have completely removed the A/C idle valve and switching valve, since then without any change. I would greatly appreciate any help. I have the FSM vacuum diagram and the lines are connected properly but no go.
Is there something I'm over looking. I will post pictures of the vacuum lines here shortly.
Blamalam
Mar 12, 2022 07:34 AM
Eggslinger
Jun 8, 2019 03:32 PM
montanatruck
Feb 26, 2017 07:07 AM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
