22re Engine wiring plug location help
Old Jul 11, 2020 | 06:18 AM
scott_schulz's Avatar
Exclamation 22re Engine wiring plug location help
I am just about finished putting my 22re back together but can't figure out where these plugs go...The white double connecter- I found the plug on the left but the one on the right is elusive, also having trouble finding the plug for the sensor that's in the thermostat housing, If you could reply specifically or with pictures that would be awesome! (it's a 1987 without A/C and cruise control if that helps)
Old Jul 11, 2020 | 10:41 AM
Co_94_PU's Avatar
Fuel pressure regulator VSV (on top of valve cover), Brake light (relatively certain this goes to the fluid reservoir?), and finally on the right is the TSW on top of your thermostat housing
Those other ones go down to the transmission/starter area and should be pretty obvious one you figure out where you tucked the other ends.
Old Jul 11, 2020 | 11:16 AM
2ToyGuy's Avatar
I am pretty sure the second picture, the white plug, goes down to the transmission. One plug, the round one I am pretty sure is for the 4WD light on the dash. I can't recall where the other one goes, though. Maybe the backup light switch off the transmission?
Good luck to ya!
Pat☺
Old Jul 12, 2020 | 03:07 PM
got it all set, thanks fellas!
Old Jul 14, 2020 | 02:40 AM
wallytoo's Avatar
it would bring closure if you were to summarize what the results were; ie, did the connectors attach to the proffered options listed above, or did they attach to something else?
Old Jul 16, 2020 | 06:27 PM
swampedout's Avatar
5 Year Member
You guys are pros!
sierra27
Jun 16, 2017 05:38 PM
Reluctanse
Nov 28, 2015 06:15 PM
Jastrunk97
Engine Swaps
Feb 19, 2015 07:51 PM
jrobb913
Engine Swaps
Aug 2, 2012 01:27 PM
Doc279
Dec 1, 2006 04:48 AM
