2 questions.
Old Jan 2, 2008 | 02:16 PM
blue87's Avatar
2 questions.
1) will a 4runner center console fit in a single cab truck with bucket seats? where is the best place to get a good used one at a good price.
2) how do i install a rear slider window?
Old Jan 2, 2008 | 07:22 PM
blue87's Avatar
anyone??
Old Jan 2, 2008 | 07:29 PM
4x4yoda's Avatar
to remove the window
get a flat screw driver and push the bottom seal from corner to corner from the inside to the outside. once the corners are out the window should come right out.
to install, get a long rope and install it around the window seal. put the remaining rope in the truck and have someone push the window from the outside toward the inside. slowly put the rope from the seal and make sure the seal is setting in the right position.
Old Jan 2, 2008 | 10:15 PM
85TurboRunner's Avatar
I'm not sure if the console will fit but if you get one from a 4Runner it will have holes in it where the rear wiper switch and rear window switch go. You'd probably be better off getting one from an xtra cab pickup since they won't have those holes.
Old Jan 5, 2008 | 03:53 PM
the_supernerd's Avatar
I got a console for my '88 4x2 when I put bucket seats in it and it did not have any mounts for it, so I had to make some. I got mine out of a newer 4Runner and the size is good. They do have holes for the rear heater and an ashtray as mentioned above, but you can't really see them in a standard cab pickup.
kawazx636
Oct 6, 2021 03:03 PM
kawazx636
Sep 29, 2015 08:22 AM
scheuvront1993
Sep 17, 2015 06:17 PM
mreagen
Sep 8, 2015 03:46 PM
defrag4
Jul 31, 2015 10:50 AM
