1994 4 Runner 5 speed swap cruise problems
Old Jan 23, 2009 | 07:27 AM
bjslade0269's Avatar
I have a small problem with finishing this swap. I bought this 4 runner after I found out my 98 runner had a rotted frame. The hg's were blown and the drivers side head had the cam journals wiped out. I fixed all the engine problems and decided to use a 5 speed from a 1991 that I wasn't able to sell. I had the remains of the 1991 and all the parts to swap into the 1994. I had a couple of issues with the electrical and 4wd but most of them have been resolved thanks to this forum. The last is the cruise control, it just doesnt work now. I swapped the speedo drive for an electronic one and the speedo works now. Could it be that I dont have the clutch pedal switch hooked up? To get the truck to start I crossed the two bigger gauge wires on the auto transmission harness (black wires, one with a white stripe, one with a yellow stripe). Maybe if they are making a connection at all times it is canceling the cruise thinking the clutch is pushed in?? If anyone could give me some direction that would be greatly appreciated.
Old Jan 26, 2009 | 04:13 AM
problem fixed
I crossed the wires on the auto transmission harness under the truck and that circuit being closed at all times would cancel the cruise control, so I ran those two wires through the clutch pedal switch and it works fine, its probably safer that way.
Goddamnboh
3.4 Swaps
12
May 11, 2016 09:22 PM
ACZR
Jun 23, 2015 07:55 PM
94hiluxZE
Jun 22, 2015 10:42 AM
Mr.Black
Jun 21, 2015 10:17 AM
bobbybouche
Jun 18, 2015 10:22 AM
