1993 hoods hard to open
Old Mar 8, 2013 | 03:48 PM
Oldiesel's Avatar
I am in the process of buying a 93 winnie camper and the hood is very hard to open,it feels like it might break something you have to lift so hard.Two others that i looked at a 90 and a 91 were the same way! Anybody know what the problem is and how to fix it,i cant believe it is supposed to be like that.TIA
Don
Old Mar 8, 2013 | 03:50 PM
85TurboRunner's Avatar
Maybe hit the gym Nancy, the hoods weight what? Thirty pounds.
Old Mar 8, 2013 | 03:55 PM
santiago0922's Avatar
you can try lubing it up with lithium grease. works on just about anything with an hinge
Old Mar 8, 2013 | 04:30 PM
Discombobulated's Avatar
Did you notice any slight front damage?? Body lines off a bit?
Old Mar 8, 2013 | 05:01 PM
Co_94_PU's Avatar
Inspect the hood latch for excessive wear and metal to metal contact, this you might be able to solve with some lube/grease. To lube the hinge you have to get under the wiper valance since our hinges go thru the upper firewall.
If they're all like that it's likely something the coach builder did, like heavy duty hinges or adjustments.
Mine is borderline danerously loose er
Old Mar 8, 2013 | 05:15 PM
So when you pull the hood release does the hood pop up at all? It kinda sounds like the hinges are dry and need a little spritz of your favorite aerosol lube.
Would be kinda nice if the OP would stick around and respond instead of posting a question and leaving.
Old Mar 8, 2013 | 05:20 PM
Oldiesel's Avatar
OK im still here,i was thinking some penetrating oil but when i get it home ill have to figure out how to get to the pivot part of the hinges,when i get it figured out ill post it here,someone else may have the same problem some day. THANKS for the suggestions.
Don
Colington
Mar 8, 2020 09:51 AM
theking11863
Mar 19, 2016 09:36 PM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
PlayAwhile
Jul 20, 2015 11:36 AM
colinmil
Jul 6, 2015 04:03 PM
