1991 4Runner Cruise Control not working...
Old Mar 26, 2012 | 09:01 AM
SLC 4RUNNER's Avatar
Question 1991 4Runner Cruise Control not working...
Maybe im an idiot but when Im driving and turn cruise control on the light does come on but when I try to set it it wont take....Does a manual as opposed to an automatic make a difference on the problem? (Mines an Manual)s Could it be a fuse? Any help on this is much appreaciated for long drives its a pain in the A#$ to not have cruise control..
Old Mar 26, 2012 | 09:14 AM
rustyf99's Avatar
I have the same problem in my 94 Runner. I read a recent post about the vacuum diaphragm being cracked and leaking vacuum, which can also cause idle and other problems. Does anyone know where we could even start with some info on troubleshooting?
Old Mar 26, 2012 | 09:22 AM
93toyrunner2's Avatar
Cruise Control
http://www.ncttora.com/FSM/1990-1995...e/cruiseco.pdf
Old Mar 26, 2012 | 09:24 AM
rustyf99's Avatar
SWEET!!! Thank you!!! This is such a minor issue for me I hadn't even done any searching, now it's at my fingertips!
SLC4Runner- take advantage of this info!!
Old Mar 26, 2012 | 01:32 PM
rdickey's Avatar
Cruise control
Mine quit working on my 88 manual when I put in a new engine. Same symptoms. Trouble ended up being the small vacuum hose that goes from the Cruise control diaphram to the other side of the engine. I would make sure that hose is hooked up right.
Old Mar 26, 2012 | 02:42 PM
ThatGuy1295's Avatar
Theres two clutch pedel sensors. One for the clutch being to the floor for your starter safety circuit. An one for the pedal being all the way up, that one enables the cruise control. Lot of times the clutch pedal isn't returning up all the way, or that sensor (more like a switch) is bad. It would be worth checking, as this has been lots of peoples problem with manual tranys and cruise control.
Charecter1
Nov 6, 2023 10:08 AM
Colington
Mar 8, 2020 09:51 AM
coryc85
Sep 9, 2015 06:24 AM
cyclist231
Jul 7, 2015 12:56 PM
zd92655
Jul 5, 2015 04:25 PM
