1991 4 runner 4 wheel drive not working
Old Jan 18, 2017 | 11:11 PM
4runnerrocko's Avatar
Hey guys I have a 1991 4 runner and the 4x4 isn't working it still has the self locking hubs not manual it's a 3.0 5 speed. So when it's in 2wd my CV axles spin and my front driveshaft does too and I can't move it by hand, but when I put it in 4 wheel drive it doesn't work, like it goes into low range and high but only the rear tires spin. I don't know what to do if someone could give me some ideas on what it could be that would be cool
Old Jan 20, 2017 | 01:06 PM
rocket01's Avatar
sounds like your not getting 4x4 when your in 4x4 mode-switch issue?
Old Jan 22, 2017 | 11:45 PM
what you mean?
Old Jan 23, 2017 | 06:03 AM
Co_94_PU's Avatar
Please clarify the bold section above. Exactly what does and what does not move when in each selector position.
Old Jan 23, 2017 | 06:08 AM
Co_94_PU's Avatar
Add tests
Power to the relay? Activation signal to the relay?
Power out of the relay to each vacuum switch?
Both switches, in place plugged in, vacuum lines routed correct?
Manually test the actuator.
