1986 Drive Shaft on a 1989
Old Sep 26, 2009 | 04:46 AM
Trail_Banger's Avatar
Hey out there.
I bent a rear drive shaft last weekend and I found a used one for a reasonable price.
Will a drive shaft from a 1986 truck, 6 cyl, 4x4, 5spd, short bed, regular cab fit a 1989 truck, 6cyl, 4x4, 5spd, short bed regular cab?
I think it will fit but realize I am crossing a generation of the truck and wanted to poll the group here for input.
Thanks!
Old Sep 26, 2009 | 05:01 AM
ILLINOISYOTADAWG's Avatar
Should work they are both 2 gen
Old Sep 26, 2009 | 06:55 AM
Yotas&Jellos's Avatar
Don't think it will work because they are from different generations.
Old Sep 26, 2009 | 07:00 AM
AxleIke's Avatar
Length is easy. Measure from the tcase flange to the diff flange. Then measure the drive shaft.
Main thing to check is that they are both single cardan (ujoints at both ends) shafts, and that the bolt patterns for the flanges are the same.
I can't remember, but its possible that the 89 will have a different bolt pattern then the 86. Easy to check though, just measure it.
Old Sep 26, 2009 | 08:06 AM
tj884Rdlx's Avatar
didn't think they made a v6 in 86. you may want to double check the year of the donor.
Old Sep 26, 2009 | 03:56 PM
Good info so far. Thanks folks!
Jun 1, 2021 01:51 PM
nanhodges2733
May 29, 2020 03:28 PM
mskalmus
May 28, 2017 07:51 AM
Iceman4193
Jul 15, 2015 04:48 PM
