Vin and IFS mistery
Old Feb 14, 2025 | 05:45 AM
22RECostaRica's Avatar
Vin and IFS mistery
Hello guys! I'm new here. Posting from Costa Rica, partly living back and forth from Maryland. I recently acquired a first generation here in CR and been wondering about some things that don't make much sense. So I joined and figured I must ask here as you guys have been doing this longer.
This car is registered as a 1984, but has a 22re and IFS.
Vin number is JT3RN65W8E5025428, which makes sense an an 84.
Model number is Rn60lg-msa, which makes sense as an 84.
And this other number:033ks11g29wg52 that I could not read what it is.
All plates on jamb, bay and/or dash have been painted over and are completely illegible.
I cant see no weld mark on the chassis for torsion bar mounts, upper arms or anything that suggest solid axle swap.
The 22re shouldn't be in a 84, neither IFS. Am I correct?
Old Feb 14, 2025 | 07:19 AM
coryc85's Avatar
Well using the Olathe Toyota VIN decoder, it says that VIN is a 1984 with a 22r. Perhaps your body got swapped onto a later frame with 22re engine and your VIN plate stayed with the body. I`m not sure if the VIN is etched into the frame anywhere, maybe someone can chime in that knows.
I just went out and looked at mine, which is 1988 and might be different for 1984, I don`t know but front passenger side of the frame right behind wheel there is a plate there (RN61-0207348), the 7 digits there after the dash match the last 7 digits of my VIN number.
Old Feb 14, 2025 | 07:23 AM
That's a possibility I never considered. I'm going to look for the engine number on the block to see if it matches
Old Feb 14, 2025 | 07:28 AM
coryc85's Avatar
I edited my post, there is a VIN like number on the frame.
cmugler
Jan 22, 2015 08:31 AM
jpmountainboy
Jun 22, 2009 04:55 PM
leebee
Nov 29, 2008 05:03 PM
FlatLandWheelin
Jul 21, 2008 11:46 AM
scott.475
Nov 11, 2003 07:26 PM
