Uggghhh
Old Aug 19, 2015 | 06:20 PM
PBRaddict#1's Avatar
Uggghhh
Ive spent a ton of time researching this on the internet nothing has been helpful to me , i just got a 1984 pickup and it runs like crap , dies when you coast with clutch in surges forward when going slower with little pedal movement then gets worse with the bounce and movment with the pedal .
So i think it might be a vacum leak or somthing i dont know , like i said i just got the truck , dont know what carb i have whats wrong or what tubes go to what , i want to replace with a new carb but i need to know what im looking at or it would be pointless , ( tried searching on here i get same results every time just a standard list that always comes up) im pretty frustrated i just want to learn how to work on it but cant find much
Old Aug 20, 2015 | 01:18 AM
Terrys87's Avatar
Looks like you have the factory Aisin carb. The 500 vacuum lines may not be connected correctly or some of the pivot points have wallowed out causing air leaks. If your emissions will allow it I would look into a Weber carb replacement.
Old Aug 20, 2015 | 07:32 AM
Yeah i want to replace it , what are the numbers associated with the weber carb ? What do they mean how do i know im getting the right carb?
Old Aug 22, 2015 | 11:34 PM
jimbyjimb's Avatar
If you want a Weber you'll need a 32/36 or a 38/38. If you're all stock the 32/36 is a good choice for most folks.
You may also use carbs from Holley or Barry Grant. I'd try to stay in the 250-300cfm range for a stock motor.
Prepare to jet it.
