tech. help
Old Oct 6, 2009 | 02:09 PM
85yota4x4's Avatar
tech. help
a coupleweeks ago i noticed my exhaust backfiring, it wasnt loud it was just little pops one after the other. so today i noticed a hose on top of the engine and it wasnt conected it was just resting on top of the hole that it is suposed to be connected to. so i lifted it up and there is a little metal piece and a spring inside of it, and the plastic connector is all chewed up, does anyone know how i can fix this? i will post pics up later today
Old Oct 6, 2009 | 02:10 PM
85yota4x4's Avatar
as you see in the pic it is in the hole but i can lift it right out
Old Oct 6, 2009 | 03:06 PM
theBurlyone's Avatar
that's your pcv(positive crankcase ventilation) valve if it's the one I think your talking about. The plastic valve with the big emissions line coming off of it that goes straight into your valve cover. I don't think it's repairable, you should just replace it.
Old Oct 6, 2009 | 03:09 PM
Teuf's Avatar
Put a wee bit of spit on there n push it in.
Old Oct 6, 2009 | 06:18 PM
myyota's Avatar
Replace the pcv valve and gromet and that will fix the problem.
wilshire
Oct 15, 2009 09:33 AM
SLOTH
Oct 12, 2006 12:38 PM
