Tacoma or IFS brake upgrade
Old Jun 26, 2015 | 05:58 AM
AustinTaco's Avatar
I can find threads on both, but not a comparison. I have done the IFS brake upgrade and replaced the Master and booster too. However, the Tacoma/3rd gen 4runner is appealing for ease of birfield removal and running IFS hubs. I like the IFS hub bodies because that will allow me to use 3rd gen wheels that will currently not slide over the SA hubs.
So...anyone had both? good , bad, the ugly? The Tacoma brackets are $99.
discuss
Old Jun 27, 2015 | 09:26 PM
osv's Avatar
osv
third-gen wheels are hub-centric not lug-centric?
Old Jun 28, 2015 | 09:33 AM
AustinTaco's Avatar
Sorry. I was referring to my 3rd gen 4runner limited wheels. They are lug centric. The hub on SFA trucks is 2 mm larger than IFS trucks
Old Aug 30, 2021 | 05:50 AM
David Cole's Avatar
Have you sold them and if not I would like them.
Old Aug 16, 2022 | 05:52 AM
rbrjr's Avatar
Brake Pads?
I get the FJ60 rotors as a replacement for the stock 1985 4Runner as they are the same overall width from font face to back face but thicker vented rotor surface. If you use the 90's 4 Runner calipers with these rotors what brake pads do you use? Stock 1985 4 Runner? 90's 4Runner? FJ60?
Old Aug 21, 2022 | 02:02 PM
jakey poo's Avatar
I used V6 4Runner pads with the V6 4 Runner calipers and FJ60 rotors. They're an impressive upgrade with very small modification.
Old Aug 22, 2022 | 10:45 AM
rattlewagon's Avatar
Drill out the ears and mount the caliper on the other side, no bracket required.
Breaking power between the two will be very similar, probably un noticeable. They both use the same caliper (unless your switching to taco/tundra calipers) Just one rotor it a hair wider.
AustinTaco
Jan 1, 2016 03:17 PM
lastname_firstname
Jun 27, 2012 01:59 PM
ItsJustD
May 6, 2012 11:53 PM
getitdone
Feb 14, 2006 11:45 AM
