popping noise coming from the RIGHT side of the front end
the noise happens when you turn, go over bumps, abruptly come to a stop, or if your off road and the suspension is flexing. The front end was just recently resealed and the bearings repacked. But the noise was there before it was resealed. You can feel it in the passenger side of the floorboard and in the steering. Any ideas
have someone turn ur wheel lock to lock then look at military wrap side of ur front leaf spring, prolly spring shifting side to side making a popping noise
i had to tighten my u bolts to cure my noise!
run your wheel full stuff to left and right like he said but sheck to see if your tires rub on your leaf springs, front or back.
i know my steer stops were loose on the knuckles and my mtrs were binding on the rear of the leaf on both side.
truckmike26
Jul 24, 2024 10:24 AM
YotaGreenhorn
Jun 27, 2015 07:00 AM
