Mysterious brake fluid loss
Old May 5, 2010 | 06:42 PM
ahickman's Avatar
Got an 84 truck (2WD, 5-speed). Have had to fill the brake fluid reservour three times in the last few weeks. I don't see ANY fluid spots on the ground where parked. Took off all four tires and inspected calipers for leaks. None! Also followed all plumbing/lines from MC to brakes. No visible leaks. Looked on floorboard below foot pedal and no leaks. Crazy! Anyone make a sugestion as to where so muc fluid could be going????
Old May 5, 2010 | 06:54 PM
sdstud212001's Avatar
brake fluid gnome?
maybe the system had a bunch of air in it and it's working it's way back to the master cylinder? Maybe drive it down a dirt road, all that dust if sure to stick to any fresh fluids.
Old May 6, 2010 | 12:28 AM
socal91runner's Avatar
Brake Fluid Loss
it might be a leaky vacuum booster - the missing brake fluid might be getting sucked into the engine
Old May 6, 2010 | 01:18 AM
iselloil's Avatar
pull up the carpet and see if its leaking from the rear seal.
Old May 7, 2010 | 07:36 PM
ilyota's Avatar
I agree with socal, I had this happen to me. The brake fluid leaks out the back of the master cylinder and gets sucked into the intake through the booster and is burned in the engine. Took me a couple of months to find it.
Old May 7, 2010 | 07:59 PM
Kiroshu's Avatar
If your absoulutley sure its not leaking externaly then its prob around or in the brake booster. Did you do any brake work recently? If so and you had lines off and did not bleed the system alot of the air will work its way out and "seem" to consume fluid.
jasonty
41
Dec 23, 2018 01:00 PM
fountain
Dec 31, 2015 06:08 AM
Tacoma1313
Aug 17, 2015 05:44 PM
Poppie51
Aug 2, 2015 11:29 PM
gmonnie123
Jul 26, 2015 02:44 PM
