Ignition Control Module gone bad
Old Oct 15, 2022 | 12:15 PM
Hoopster1978's Avatar
1985 22re with bad ignitor, searched, at a loss for a fix, replacement. Any suggestions, sources. At a loss on what will work.
Old Oct 20, 2022 | 12:36 PM
Baller's Avatar
What makes you think it's the ignitor that's bad?
Time for a trip to a local pick and pull?
Old Oct 20, 2022 | 06:16 PM
Melrose 4r's Avatar
5 Year Member
Some people have retrofitted GM ignition modules. They are cheap. I read it on Ih8mud.com maybe.
Old Oct 22, 2022 | 11:20 AM
osv's Avatar
osv
the ex53 module? https://www.rockauto.com/en/moreinfo...89341&jsn=1106 fits '85-'88 22re
it's been out of stock for a long time, at all vendors, i put in a stock notification at rockauto and managed to nab one for $114, which was a good price... it seems to work fine, but the wiring is smaller diameter, which is disappointing; i tore the original unit apart to see what was inside, it's totally not serviceable.
worst case is that there are a lot of listings at the junkyards... see the bottom of this thread for cross-referenced part numbers: https://www.yotatech.com/forums/f116...-motor-305381/
when this ex53 ignitor fails, the engine will not start, you are dead in the water, so carrying a backup is probably a good idea.
Yamalol
Jan 15, 2024 01:53 PM
Allysa Chandler
Nov 1, 2018 06:52 AM
irv
Jun 30, 2017 10:31 AM
KYcrawler
Feb 26, 2010 12:32 AM
pursang
Apr 4, 2008 09:24 PM
