High idle with the A/C off
I got my A/C working yesterday by putting a belt on the compressor and recharging the system. With the A/C on it it idles a Little high but sounds right to compensate for the load of the A/C. With the A/C off however the motor is revving I'm guessing to around 1000-1500 RPM's. Any ideas on what to check to get it to idle normal with the A/C off? My truck is completely stock and has not been modified. Has a little over 27000 miles on a 22r.
the following link has a picture of the oem Asian carb with the adjustment screws labeled.
disclaimer: I would not adjust the air/fuel mix screw without a manual it seems to be more trouble then its worth without having the instructions with you.
https://www.yotatech.com/forums/f120...a-smog-264872/
