So the bolts from the bell housing to the engine fell out. I don't have any bolts to be able to compare size, so I don't know what they are. I believe on the forums the consensus is M12x1.25 but I haven't been able to find the length. 1985 22re
And does anyone know what size the bolts used to thread in the brake drum so that I can get it off and change my brake shoes?
[QUOTE=jonathondk;52344766]So the bolts from the bell housing to the engine fell out. I don't have any bolts to be able to compare size, so I don't know what they are. I believe on the forums the consensus is M12x1.25 but I haven't been able to find the length. 1985 22re
hello jonathondk, if you are referring to the bolts that hold the stiffening brackets to the bellhousing in the your photo those bolts are M10x1.25x35mm on my 85 4runner with 22re and auto transmission. The M12x1.25 is the size of the 4 main bolts (2 up top, 2 down bottom) that actually join the engine block and transmission bellhousing.
