backing plate bolt pattern
Old Mar 29, 2012 | 11:18 AM
longbed's Avatar
I'm wanting to build a better rear wheel bearing removal tool to replace the angle iron contraption I did in a hurry the last time I needed one. I mostly need it for '85 skinny axles. Was going to cut up a spare 87 rear axle to make a tool, but remembered I have a 95 rear housing that's one step from the scrap pile. Think that will work with a little notching of the stud holes or is it too far off?
Old Mar 29, 2012 | 11:32 AM
waskillywabbit's Avatar
You mean make a SST rear seal bearing puller?
It's the same rear axle for the most part 79+
:wabbit2:
Old Mar 29, 2012 | 11:54 AM
longbed's Avatar
I was going to make an sst like the one pictured, seemed a little less work than having to cut the flanges out of steel plate. I recall the bolt pattern on the 86 and later being larger than my 85 axle, no idea about the mid 90's runners. I might just need to get an early axle? I guess I'm wondering if the stud are going to be so close to the larger tube I won't be able to get a nut on them.
Jun 1, 2021 01:51 PM
icentropy
Sep 16, 2020 02:47 PM
mskalmus
May 28, 2017 07:51 AM
elwood73
Jul 5, 2015 07:07 AM
