Alternator problem
Alternator problem
Over the past few days it has been 100+ here in the midwest. I have been noticing my truck losing battery power. It finally left me stranded today. . . .I hopped out and found the Battery to alternator wire was arking out around the bolt that secures it to the alternator, eventually destroying the connection. I was on the side of the road so i cut the wire, cleaned it up, and wrapped it back around the bolt and tightened it till it smashed the clean wire back down. Got a jump and drove home, now nothing but a click. Will try replacing alternator when it cools off, just seeing if anyone had experience with this issue before . . . thanks much.
Ive heard of a few people here having that problem, but its not a common problem. The nut on the alternator probably just came loose, and when it does it starts arking and eventually burns through the stud on the alternator.
