1985 Toy w/o Power Steering
Old Apr 27, 2011 | 03:33 PM
ebakley's Avatar
Would like to know about putting power steering in my Toy.
Is this a major project or just a weekend upgrade??
Thanks
Old Apr 27, 2011 | 03:51 PM
SCToy's Avatar
Search for hi-steer. It's not that hard, it can be done in a weekend if you gather all the parts and plan it out. Click my build thread and you can see the basic idea of what you need to do. I just did it a few weekends ago on my 81.
Old Apr 27, 2011 | 04:01 PM
algranger's Avatar
Histeer is DEFINITELY the way to go. Would probably consume a full weekend and cost you roughly $400
If you dont want to drop that much, the power steering (ps) conversion is pretty simple. You will need to find a parts truck on craigslist or a junkyard.
You will need the following:
-3rd row crank pulley for the ps belt
-ps pump and mounting brackets
-ps hoses (high pressure from the pump to the box, return from the box to the res and supply from the res to the pump)
-ps box from any straight axle rig
Everything will bolt right on and you will be rollin in no time. I think it took me about 2 or 3 hours to do this conversion on my 84.
When i eventually went to histeer it took about 6 hours but would take you longer since i already had the under-hood components installed.
Old Jun 3, 2011 | 08:45 PM
minorthreat's Avatar
Thanks
easy to do .should take about an hour to replace the box and add the pulleys and pump.
Last edited by dropzone; Jun 3, 2011 at 08:54 PM. Reason: censor picked up on language
Zpd426
Jan 2, 2016 01:15 PM
Up&Down
Aug 11, 2015 10:04 AM
gmonnie123
Jul 26, 2015 02:44 PM
yoterr
Jul 24, 2015 04:29 AM
whereAreMyPants
Jul 22, 2015 03:32 AM
