1984 22r that is a puzzle for not firing up
Back story, bought it 5 years ago and drove it home..ran great...fire it up from time to time, while sitting, ran fine. 5 years later, have dropped 7 grand into making it a daily driver/Oregon backwoods wheeler. Have changed fuel lines, filter, new cap, rotor plugs and wires. Would turn over, but no spark. Replaced coil..nothing...did more troubling shooting..diagnosed as pick up coil, in stalled it, has spark, but still won't fire up. Find out, that probably while sitting at ex wife's house, someone messed with pick up coil, as well as moving distributor 20 degrees off. Corrected all set cylinder to one, distributor to one belt to one...everything in line...turn it over and when we checked timing, on two different guns. Where it should have been on one..was on the opposite side..pulley is I suspected and good. Other info...has a webber 380 on it, when turning over it is back firing out of the carb, which I take as being out of time. Any onsite or ideas would be helpful and appreciated.
Moderator: Merge this thread with this one: https://www.yotatech.com/forums/f114...ing-up-308687/
karuso86pu
Jul 22, 2015 10:39 PM
Thenewguy16
Apr 18, 2014 06:00 PM
