Pre 84 Trucks 1st gen pickups
Will it work 81 22r into a 86 22r pickup
Old Nov 19, 2020 | 08:16 AM
Upsidedown86's Avatar
I have an 86 pickup it has the 22r in it and is 4x4 with the 5sp. I also have an 81pickup with the 22r it is 2wd with the 4sp. I would like to swap the 81 motor into my 86 but I’m not sure it will work. Is there any reason this motor swap won’t work?
Old Nov 19, 2020 | 07:25 PM
Trueblue93's Avatar
It will bolt up just fine to your transmission. Swapping early short block for late short block is a no go. If you are swapping the entire motor it will work. You'll need the header from the older block also. The header exhaust ports are different for early blocks (round port if I remember correctly).
Tim O'Rourke
Nov 19, 2020 10:21 AM
I8URSVT
Oct 5, 2015 05:42 PM
jburress10@yahoo.com
Nov 11, 2013 11:56 AM
