ifs rear end swap??
ifs rear end swap??
ok i know its 3 inches wider but will i have to make new shock mounts and do a u bolt flip? also i found a cheap one off a 92 4 runner. if the 4 runner is a v6 that means i wont be able to put the 3rd member with my 529s off the stock 4 cyl rear end on to the new v6 one right?
4cyl and V6 thirds are compatible. So yes you can put your third in there.
The 4Runner rear will have a lot of brakets for the suspension (since it is a coil suspension) so yes you will need to weld on new spring perches. You may or may not be able to use the factory shock mounts.
Jun 1, 2021 01:51 PM
FS[SouthEast]: Mercury Villager Fan & DCC Fan Controller
coryc85
Sep 9, 2015 06:24 AM
