Can you tell me when the corner lamps next to the round headlamps are supposed to light up. Are the reverse lamps in the front? Are they supposed to light up when the brights are hit? Your help would be appreciated. Thks
they are 'city lights' and are on when the headlight switch is turned to the first click.
in many countries these will be used at night in urban areas to reduce glare, etc.
Thanks both my bulbs must be burnt out then. I will replace bulb and see what happens.Originally Posted by ducatipaso
they are 'city lights' and are on when the headlight switch is turned to the first click. in many countries these will be used at night in urban areas to reduce glare, etc.
They turn on with the first click and should stay on when the headlights are on as well.
