Bells and Lights
Bells and Lights
I am looking for what may be wrong with the light in my climate control unit. The light bulb is not burned out as it does come on every once in a while.
One time my seatbelt beeper went off on startup, and I do kind of like the beeping noise it made as it was very old fashioned.
My door button on the left side is bust and whatever noise emitter for that is it is no longer wired up either.
How do I replace the door button?
Could anyone give me information on what could be wrong with any of these things/what the common problems for them are? I will use a signal tracer if I have to unless there is some kind of common problem/problems you've had.
Thanks
1983 short bed 4x4
Thanks
1983 short bed 4x4
I think most people are happy when those noises die, so you may not get a lot of help fixing them. I would think with most stuff like this, it's going to be in the wiring, somewhere that it gets bent regularly and has shorted out. I think checking the continuity of the wire and circuit is going to be your best bet.
Usually it's either damaged wires or dirty, corroded connections and terminals. Other than that, I don't really have specific "look at this particular spot" advice...
wiseguymmiv
Nov 13, 2015 08:56 AM
wiseguymmiv
Nov 9, 2015 12:22 PM
WTB[SouthEast]: bell housing and transfer case adapter
mrnick1979
Oct 17, 2015 06:28 PM
