Pre 84 Trucks 1st gen pickups
Attn 79-80 4WD owners: You can now have Bigger Brakes
Old Jun 21, 2012 | 08:54 PM
dropzone's Avatar
Fossilized
79-80 Truck owners have been kind of getting the short end of the stick when trying to do the conversion with V-6 Calipers and FJ Vented Rotors. I found this info on Marlin:
paged 103 of this thread: http://board.marlincrawler.com/index...213#quickreply
for those 79 and 80 owners you don't need to swap to 81-85 hubs. just drill 4 holes.
79 pickup hub
LandCruiser rotor
Land cruiser rotor sitting on the 79 hub. notice the two small holes are lined up with two of the holes that the 79 rotor used to bolt to the 79 hub
then using a 5/16 drill bit line up the threaded holes and drill the new 4 holes in the rotor.
once they are drilled remove the rotor and use a 3/8 drill bit and open them up so the bolts slip through and then bolt it on with the original 6 bolts.
Old Jun 24, 2012 | 09:15 AM
Pillowthread's Avatar
Vote!
Um......sticky?
Sep 4, 2015 09:27 AM
ripp96
Jul 31, 2015 11:14 AM
harrisdawg
Jul 26, 2015 09:42 AM
ripp96
Jul 25, 2015 02:32 PM
