Pre 84 Trucks 1st gen pickups
anyone have Carb Rebuild experience?
Old Mar 1, 2012 | 06:11 PM
Cibarius's Avatar
I'm looking at starting to piece the lower part of my '78 20r (aisan) carb back together after cleaning and I noticed that the gasket holes don't line up with a small hole on throttle chamber. It's a hole that correlates to the triangular well on the underside of the carburetor body, which runs through to the air horn. (don't know where it goes from there)
Should I punch a hole there to make sure it's unobstructed or is this something that should be left as is?
Old Mar 1, 2012 | 08:50 PM
MercuryMan's Avatar
Pictures? You might have a replacement carb from a different R engine. They are all very similar but not all the same.
Old Mar 2, 2012 | 02:02 PM
Cibarius's Avatar
resolved the issue today. my carb is put together a little differently than what the service manual pictures indicate. it must be a '79 carb or something, I noticed that the manual also indicated 2 choke diaphragm assemblies, mine only has 1 but that's the only major difference.
gaskets lined up ok once I realized that and got them oriented correctly.
Old Dec 15, 2015 | 10:18 AM
gforcepdx's Avatar
which carb do I have?
is their a page here to identify which variant carb I've got on my 20r? I'm buying a 77 longbed that likely needs a carb rebuild.
Old Dec 17, 2015 | 10:29 AM
wolfpackfan33's Avatar
I have my carb rebuilt and my truck still had issues running and idling. Switch to a Weber and it has been great. Not sure if that is an option, but I would definitely recommend a Weber.
foampile
Dec 18, 2022 01:29 PM
tomczaksdiesel
Jul 26, 2015 10:35 PM
Yota.Jay
Jul 23, 2015 08:08 PM
jgallo1
Jul 22, 2015 04:21 AM
