Pre 84 Trucks 1st gen pickups
alternator has fear of water
Old May 24, 2008 | 02:14 PM
Al's Chop Shop's Avatar
its no surprise the alt doesn't like water, but just hitting a small puddle caused the dash light to come on for a few minutes. after it dried out it was fine the rest of the night. but today the light was on for 1/3 of my 30 minute drive to work with no water in sight. surely its dried out by now? do i have signs of a failing alt or is just a little water to blame? i'm going wheeling tomorow and don't want to be the guy that needs a jump start every time....
Al
Old May 25, 2008 | 07:57 AM
Team420's Avatar
Bad ground???
Old May 28, 2008 | 03:51 PM
brooklee1000's Avatar
99% of electrical problems are bad ground. BUT...if that not the problem, use a voltmeter, check voltage at the battery terminals. When running, should read 14volts or so. Anything less, check battery, but likely need to replace the alt at that point. I run a chevy alt beneath the intake (p-side). Cheap to buy and replace when damaged from dunking.
Old May 28, 2008 | 04:46 PM
i'll give it a check. how many engine to chassis grounds should there be... and where?
Al
Old May 28, 2008 | 06:13 PM
dropzone's Avatar
Fossilized
GM alternator swap bracket
Might be a time for an upgrade. I bought one of these:
https://www.yotatech.com/forums/f37/...-mount-139305/
outstanding work on the bracket, I just need to get my GM alternator and time to work on the truck...
80Truck
Oct 12, 2025 07:25 PM
greasyglue
Dec 12, 2015 12:57 PM
sanctfy
All Other Toyota Swaps
Sep 15, 2015 02:52 PM
Sep 4, 2015 09:27 AM
shrek99352
Aug 31, 2015 04:16 AM
