Pre 84 Trucks 1st gen pickups
83 yota 3in rough country lift need shackle help!!
Old Jun 20, 2014 | 04:41 AM
1989mpe's Avatar
I'm new here. Just got a 83 toyota with a 3 in rough country lift already installed but my shackle angle was terrible (/) instead of this(\) I can figure out how to make it right. I tried lifting the truck and prying it right that didn't work an I tried seeing if the spring was backwards with no luck either. Any help would be appreciated it rides like a square wheeled wagon like it is and the shackle laying against the frame isn't helping any. If anyone has any ideas I would appreciate it. Thanks
Old Jun 20, 2014 | 07:46 AM
sandman666's Avatar
sounds like the springs are too short. i think the only way you can fix it and still use those springs would be to move the shackles forward on the frame.
Old Jun 20, 2014 | 08:54 AM
1989mpe's Avatar
I hope not I have the same springs up front an they measure out right but there is a lot more weight up there. So hopefully with a bigger pry bar and some will power I can get it right or close to right an put some,weight in the bed and hopefully it will settle in the,correct position with time?
Old Jun 22, 2014 | 07:28 AM
Batousaii's Avatar
I have rough country springs too. Mine were a bit fickle durring install, had to hook up the shackles and slowly lower the truck making sure they went the right direction. Now that they settled in a bit, they are fine. I think R/C simply curves their springs a bit much, so they are a pain. - Now that they got a few hundred miles on em, i'm happy with them.
- Word of Warning!! - CHECK YOUR PINION ANGLES! , mine was making a vibration after install, $150 worth of chasing this mystery vibration led to realise my pinion angle was off. https://www.yotatech.com/forums/f114...y-gear-281368/ ... some measuring and a simple set of $25 dollar wedges would have saved me a world of worry.
Good Read -- > http://www.4crawler.com/4x4/CheapTri...l#Measurements
Hope it all works out for ya.
Old Jun 23, 2014 | 08:54 AM
1989mpe's Avatar
Thanks for the response I'm going to out it back together an see what I can some up with I called rc an they assured me it was right. As for the pinion angle when I'm driving an I Let off the gas just coasting it makes some kind of awful noise but when I o it it back under power it stops it sounds the u joints but if my angle is off maybe that could be it too? I haven't investigated it yet I'm just trying to get the springs strait first lol
Old Jun 27, 2014 | 01:38 AM
1989mpe's Avatar
Got them going right now it took a 4ft pry bar an lots of elbow grease it I got them flipped put a good it of weight in the bed so they can settle.
Old Jun 29, 2014 | 06:16 PM
83Toyota88's Avatar
I have the same lift and moved my shackles to fix the angle.
Flying91
45
Apr 11, 2024 04:39 PM
Sep 4, 2015 09:27 AM
Sr5crawler
Jul 31, 2015 12:32 PM
coffey50
Jul 28, 2015 10:55 AM
skoti89
Jul 6, 2015 07:45 PM
