Pre 84 Trucks 1st gen pickups
22r annoying oil leak!!
Old May 14, 2013 | 02:58 PM
cman1's Avatar
alright ,has anybody ever had oil leak out of the dizzy hold down bolt????
Old May 14, 2013 | 03:14 PM
maachine's Avatar
there should be a gasket in there that needs replacing. pop the dizzy out and you should see it
Old May 14, 2013 | 03:56 PM
cman1's Avatar
its not the o-ring,its actually dripping from the hold down bolt.o-ring is new.
Old May 15, 2013 | 09:02 AM
enigmaT120's Avatar
Did somebody punch that hole all the way into the valve area? Like with too long of a bolt? I don't know how thick the metal would be between that bolt and the inside.
Old May 15, 2013 | 09:31 AM
cman1's Avatar
that's kinda what I was thinking, last night I pulled the bolt out and cleaned it and put it back in with fipg. if that fixes it ill pull it back out and do the same thing with a stud. well see.
Old May 15, 2013 | 11:34 AM
maachine's Avatar
ya i was going to say the same thing. it'd be weird if they made the hole go all the way through.
Old May 15, 2013 | 02:25 PM
cman1's Avatar
Well,so far it worked.ill check it every day and if its good,ill put a stud in.
Eggslinger
Jun 8, 2019 03:32 PM
cars-guy
Jul 11, 2015 07:51 PM
jakebarrett
Jul 10, 2015 07:15 PM
Coreyr384
Jul 10, 2015 11:13 AM
87blyota
Jul 10, 2015 04:31 AM
