Pre 84 Trucks 1st gen pickups
20/22R hybrid timing issuse
Old Jun 9, 2013 | 09:47 AM
Rollz79's Avatar
So some info on the engine. 79 20R head been milled to make flat. EB Over sized valves and a mild port and polish,LC dual valve springs, LC adj cam gear and bigger cam 290.
81 22R block with dome pistons,all ARP's,MLS head gasket, everything else is OE replacements. I have a weber 38 on it also.
I can not get the engine to time right. it pings under a heavy load. I can pull 1st and 2nd with no issue 3rd and 4th ping under throttle. I have a LC pro Dizzy. I can't get it to line up to 0btdc with a timing light with out it dieing. So its set a 8btdc with out vac ad hooked up. Ive tried to move the dizzy a tooth back wont fire that way.
any idea's?
Old Jun 13, 2013 | 03:25 PM
Yopar's Avatar
Did you degree the cam in? Make sure it isn't off a tooth.
Also, make sure the fuel octane is good for your compression ratio.
Jun 1, 2021 01:51 PM
Eggslinger
Jun 8, 2019 03:32 PM
Sep 4, 2015 09:27 AM
thefishguy77
Jul 30, 2015 10:59 AM
