1982 front driveline cv joint bad
Hey everyone I got a 82 short bed & the cv joint on the front drive line is bad. I checked it & it has a lot of play in it. It also makes a lot of clacking noise when I put it in 4wd & lock the hubs. Anyways I've never replaced one so I am wanting to no ware to get one & how much they cost. Also is their a tilt steering column I can put in it.
Thanks Erik
Thanks Erik
I would think it's the front drvshaft !!
not sure where you USA guys can get a new shaft from , I would think some guys like pats drive line , if you have em in the US .. i'm sure some one else will set you straight on that .. and i believe your correct when you say " & it has a lot of play in it. It also makes a lot of clacking noise " as to REPLACE it .
you can rebuild them , but not the splines , and the "play" is most likely the splines .
you can also put any tilt unit from 81-83 truck , just make sure you get the colum cover as well
I was talking about the cv joint on the front drive line wright ware it bolts to the transfer case. The play in it is I grab it & push on it it moves up & down more than I think it should. As far as the steering column I was just wondering if their was any out their for my truck. Hope this explains it better.
FS[GreatLakes]: Toyota collection part out
88sasturbotoy
Jan 30, 2026 01:57 PM
jasonty
41
Dec 23, 2018 01:00 PM
Sep 4, 2015 09:27 AM
