FS[SouthEast]: 87 4Runner SR5 4x4 A/T $9500 OBO
Old Sep 12, 2023 | 11:31 AM
cikphrek's Avatar
87 4Runner SR5 I was building for my son when he turned 16. Well, decided he didn’t want it. Odometer shows 262K, but engine and transmission were rebuilt at 257591, so basically under 5K on them. Nothing from the old engine was carried over to the new one. About the only thing still original under the hood is the charcoal canister, wiper motor and fuse/relay box. A/C system was also completely rebuilt with new components at this time. Only thing that doesn’t work is the cruise control, the rear window defroster and the auto slide on passenger seat. Passenger front fender was replaced with a factory fender I found out in AZ because original had some damage when I bought the truck. And of course, about 2 weeks after I put it on, a tree branch fall on it and dents it.
A/T, PW, PL, Power Mirrors, Power Antenna, Sunroof, Tilt Wheel
I’ve attached 1 photo, but here’s a link to over 100 more
https://photos.app.goo.gl/uaRavqjKcnEbYRVd8
Listed below is what’s been done to vehicle during/since the rebuild.
Engine .040” over
Egnbldr StreetRV Head (1 mm oversized valves)
Egnbldr 268C camshaft (268 degree / .425” lift)
Fuel system converted to manual FPR
82 Supra AFM w/LCE K&N kit
Throttle body bored and upper intake plenum bored to match
Battery Swap
Aluminum Radiator w/electric fan
Pacesetter Header with full 2.5” exhaust
High Output Coil
Oside Tiger 4 hole high impedance injectors
A pillar gauge pod with Volt, Air/Fuel and Trans temp gauge. Trans temp gauge is bad due to me connecting a wrong wire.
New factory power window switches
New power window motors, regulators and window track rubbers both front doors
New rear window power motor
New bushings in the shifter
New gas tank, fuel pump and sending unit
New steering box
New PS pump
New tie rod/drag link ends and idler arm
Have new upper & lower ball joints, not installed
Upgraded to dual diaphragm brake booster and 1” master cylinder
Upgraded to 88 V6 4Runner 4 piston calipers
Upgraded to slotted cross drilled front rotors
New front wheel bearings
New brake lines, only factory hardlines not replaced
New rear drums
New wheel cylinders
All new brake hardware
New Load Sensing Proportioning Valve
All LED lights
New rear pinion seal and Yukon Gear yoke
New front fender inner liners
New wheels and tires with maybe 50-100 miles on them
Brand new spare
Add-a-leaf leveling kit
The following have somewhere in the 8-10K miles on them
Front CV axles
Pro Comp shocks
New urethane bushings in rear leaf springs
mlaurie
Nov 23, 2013 10:30 AM
3YLSYKR
Jul 25, 2013 01:53 PM
jasonomni
Jun 12, 2007 07:05 PM
sschaefer3
May 18, 2007 10:05 AM
sschaefer3
May 18, 2007 07:27 AM
