1996 4Runner 4x4 Limited -$8K firm
****SOLD****
Up for sale is a 1996 4Runner Limited. 185K miles. Auto transmission. This truck has been wheeled on the AZ trails. It DOES have AZ pinstripes. If you are looking for a truck with perfect paint, this truck is not for you. I bought the 4Runner with 166K miles from an older lady who maintained the truck and was provided full maintenance receipts. The thought was to build this up for the AZ trails. Currently the truck has not been driven much due to new toys. Would like to free up the driveway. All maintenance and work done since purchasing the truck has been document in a spreadsheet and will be included with the purchase of the truck. $8000 firm.
-TJM-15 front bumper, brackets reinforced/adjusted for 1.5 BL, wings bobbed by SS
-4 Crawler 1.5 BL with heavy duty hardware, 9th and 10th body mounts added, steering extension
-99 Front Grille
-99+ Headlamps
-Stubbs Rubicon Double Kick Rocksliders
-Sonoran Steel custom rear bumper
-Sonoran Steel lift kit 1.1 with upgraded Blue TRD Tokico front shocks
(http://www.sonoransteel.com/store_co..._liftkits.html )
-Bud Built front and belly skid plates
-ARB RD-90 up front, E-locker in the rear
-5.29 gears with rear set cryo treated
-Power steering cooler mounted in the front
-Transmission cooler mounted in the front
-Stainless steel braided brake lines
-Optima Red top battery
-MT Classic II 16x8 3.75 BS
-Cooper Discoverer STT 315/75/16 with Discount tire certificates (only used 6K miles)
-Full size spare
-Timing belt, water pump, fuel filter replaced at 166K miles
-Both oxygen sensors replace at 168k miles
-Toyota OEM brake pads and Brembo OEM rotors at 169K
-New axle seals at 175K miles
-New Toyota power steering pump at 178K miles
-Steering rack replaced at 180K miles with Energy Suspension bushings
-Wheelers front sway bar bushings
-All synthetic fluids in the drivetrain
-Absolutely no leaks, no rusts at all
Tear in driver seat
AZ pinstripes
Hi Lift not included
-99 Front Grille
-99+ Headlamps
-Full size spare
Tear in driver seat
AZ pinstripes
How is the on the road drive with the gearing (revs/power/etc)?
AZ all it's life (i.e. no rust)?
Speedo calibrated?
Rami
Speedo calibrated?
Rami
It dives great on the road. I'm sure everyone's has an opinion with gearing, but I think 5.29s are the way to go with 315s and an auto.
It's an AZ car... no rust at all.
Speedo not calibrated. If I remember correctly, it's about 5 mph off at 60 mph.
progress4m
Oct 27, 2005 11:59 AM
highway74
Sep 17, 2005 07:24 PM
Ashburner
Mar 25, 2003 03:33 PM
. I'm sure the new owner will love it.
