How do you disable auto-arm?
Does anyone know how to disable the auto arming feature on a 95s factory keyless/alarm system?
The remote has 2 buttons and 1 red LED, I'm unsure of any switches and such elsewhwere.
Its driving me nuts!
Thanks,
Lamm
Thanks,
Lamm
I'm working out a install on my new ride that I'm trying to integrate with the stock alarm and have discovered that the alarm has two modules under the dash that are zip tied and taped together.
One of the modules has four little switches in the upper corner on the face of it which, when you look at it, you'll find that # 1 is in the "on" position while #'s 2, 3, & 4 are in the "off" position..., setting switch #'s 2 & 3 to the "on" position with #1 will set the system to "active" mode which will only allow it to be "armed" with the use of the key ring transmitter.
Hope this is what you're looking for and now if I could only get help with my alarm/stereo problem...(hint-hint)
theking11863
03-19-2016 09:36 PM
jmyer72
08-20-2015 07:55 AM
hillbilly
23
04-28-2011 09:20 AM
