Rear Bumper Fab Underway
Old 06-30-2008, 03:26 AM
abj27's Avatar
Looks very clean. What are you using for all your cuts?
Old 06-30-2008, 07:52 AM
WillRadford's Avatar
I used a neighbor's metal fab shop. He has a nice big shear. Very handy.
Old 06-30-2008, 07:54 AM
Originally Posted by John S.
Looks great so far, no plans for a spare tire carrier?
I'm going back and forth on that. I need to look at some different designs for spare tire carrier, and I'll need to find a tube bender. Maybe this will be a good excuse to go buy one.
Old 06-30-2008, 08:01 AM
Originally Posted by AZ4ME
Not sure if the body and frame flex on a second gen like they do on a third, but if you have any part of the bumper rubbing or quite close to the body now, you may want to re-think that clearance. I would want, at a minimum, an inch clearance away from the bumper and any body part. Otherwise, if you hit the bumper hard, you stand a good chance of getting some body damage. Just a thought.
The bumper is really stiff, but your right, the sides could deflect and do damage to the body. I don't think I need to worry too much about the main tube section bending, or even deflecting, unless something real crazy happens. The main mounts for the bumper are 1/4" plate, which bolt up to 1/2" plate (the old trailer hitch mounts). The sides will be supported off the main vehicle frame with 1 1/2" sqr tubing, but they are the most vulnerable. To me right now though its not worth rebuilding it to make for more clearance.
Before reading your post I really hadn't thought too much about clearance, so I appreciate your feedback.
Old 06-30-2008, 11:21 PM
  #25
-TheBandit-'s Avatar
Without seeing the insides of those wing sections or how you tied them into the frame, it's tough to say how well they'll hold up. Definitely fully box them at the bottom and tie them into the frame at the front if you haven't already.
It's a nice looking design. Look forward to seeing the finished product.
Old 07-01-2008, 04:21 AM
  #26
dirtoyboy's Avatar
I would highly recommend the JD2 bender
Old 07-15-2008, 08:38 PM
  #27
So I've got all the welds done. Some are prettier than others. After my grinder stand and some auto body work, this was my third welding project. I think all the welds laid on pretty good. The fillet welds look much better than the butt welds. Those long butt welds were tough to make look nice. But, I've decided to grind all the butt welds off so that it looks nice for the powder coating. Do you guys think this is a standard thing to do on bumper fab? Grinding off the butt welds? I understand that it will compromise the strength of the weld, but I want to finished product to look good.
Well, here are a few pics of the welds:
After some grinding:
Old 07-15-2008, 08:44 PM
  #28
nix4x4's Avatar
Simple yet functional... the essence of our old Toyota's.
I like it.
Old 08-06-2008, 12:56 PM
  #29
vermontoyota's Avatar
looks great. I'm planning on doing the same thing you have done with bedliner. That is professional right? How much did it cost?
Old 08-06-2008, 03:15 PM
  #30
I slapped on the bedline to the bottom of the runner myself. Just taped it off and threw it on there. Used Herculiner. I think it cost about $40 or so. Pick it up at Autozone or wherever. Hard part is taping off the arches that go around the wheel wells. I put the UV protectant on about a month after I did the bedliner. I didn't apply the UV protectant liberally enough so there are spots where you can tell it isn't as shiny as the rest because it didn't get enough UV protectant. I will probably touch it up one of these days.
Old 08-06-2008, 10:15 PM
  #31
shancerlelby's Avatar
stole all your pics one day when i take em and get one built i'll give you credit for the killer design.
Old 08-11-2008, 09:07 PM
  #32
OK, ready to be powder coated
So I've got all the welding done and grinding done and its ready to be powder coated black. Well, I lied, Im going to drill out the clevis lugs to 5/8" or 11/16" dia. If I buy a 5/8" clevis is the pin undersized so it will fit in a 5/8" hole, or is the pin exactly 5/8" dia? I know the working load on a 5/8" stainless clevis is only about 5600 lbs, but that is with a 5 - 1 safety ratio. Do you guys think this is going to be undersized? Well, if it is, too bad, because I'm not tearing off the existing lugs so that I can weld on bigger ones that I can drill a 3/4" or 1" hole in.
ANYWAYS, after I welded up the whole thing I put it back on the truck and my worst fear had slightly come true. Warpage. The sides had warped down a little bit. The driver's side warped down about 3/8" and the passenger side warped down about 1/4". So I guess really that isn't too bad, but even the smallest blemishes drive the fabricator crazy. I don't know how I could have prevented that warpage though. I tacked it together about every one to two inches before I laid the main welds down. Oh, and the other mistake that is driving me nuts is the two pieces of steel on the right and left of the female hitch piece with the holes in for the trailer chains: one is about an 1/8 inch lower than the other. I don't know how I welded those up without it being perfect. I guess thats what happens when you get to the very end of a project. You just want to be done and see it on the truck.
Oh, and the other last thing I need to do is make my side supports. Im going to use some square tubing to tie in the sides of the bumper to the truck's frame at a 45 degree vertical angle. This will be a bolt on piece and I'll wait to do it until after it comes back from the powder coater, just in case it decides to move at all on me again after being in a hot oven.
OK, here are some pics. For the amateur welder that I am, Im pretty pleased with how it turned out. I'll post more pics after its powder coated:
Oh ya, and ignore the dirty truck.
Old 10-04-2008, 03:13 PM
  #33
Done finally
OK, so Im finally done with this thing. I got it powder coated black, as you can see, and I put on some diagonal supports for the sides. I welded the supports to the frame and bolted them to the bumper. Im happy with it. I think it turned out looking really good. I guess now I just need to get it out on the trail and see if it'll hold up. I need to do something about my exhaust pipe still. It sticks down too far now.
Welding the support to the frame was a pain because of the angle I was at. You can see from how pretty the weld is...
Old 10-23-2008, 07:23 AM
  #34
toyscraps's Avatar
Very nice. I think the exhaust would look good exiting thru a hole in the bumper "side", just above where it is now.
Old 10-23-2008, 07:46 AM
  #35
trbizwiz's Avatar
That thing is SICK. Nicely done.
Old 11-16-2008, 01:58 AM
  #36
Matt16's Avatar
I like it alot. I'm hoping to do somehting like thus, but with a tire carrier. What gauge DOM tubing did you use for the main part?
Old 11-16-2008, 07:24 AM
  #37
I think I used 4X3X1/16 square tubing. That was the most expensive part. It cost about $70.
Old 12-04-2008, 06:44 PM
  #38
JohnRaven's Avatar
I'm curious... What are the dimensions for the connecting plates???
Old 12-04-2008, 07:11 PM
  #39
89silverpu's Avatar
Just the exhaust pipe and put a turn down on it...
Old 12-05-2008, 06:33 AM
  #40
The plates that connect the main section of the bumper to the trailer hitch plates are quarter inch. The trailer hitch plates that are bolted to the frame are half inch.
Quick Reply: Rear Bumper Fab Underway
