92 22re to carb???????
Old 12-27-2013, 09:33 AM
I R Dielawn's Avatar
I have an 88 toyota 4x4 that someone put a 22re out of a 92 pickup and all the wiring is cut and spliced into places and it will not run. What are the odds of turning it to carb???
Old 12-27-2013, 12:59 PM
wyoming9's Avatar
Red face
About the same as you getting this one running.
Only different.
You would need to figure out how your getting fuel
Electric Pump with a pressure reducer in the engine compartment.
Figure out a way to power the electric pump.
Manual pump on the head making sure to have the eccentric behind the cam gear to drive the manual pump
The fuel lines to adapt to the efi lines..
The carb ECU and sensors for the ecu you end up with
Merge the new ECU into the truck harness
Manifold and carb and assorted Electric Choke parts
Not sure about if the throttle cable will need to be changed.
As this is just off the top of my head I am sure a bunch of little things I forgot.
Old 01-13-2014, 04:33 PM
skoti89's Avatar
It'd be easier to figure out the bugs in your set up now.
Old 01-13-2014, 04:52 PM
86toyotaprerunner14's Avatar
I'll trade you all the carb stuff for all your efi stuff
Old 03-15-2015, 11:00 PM
Tyler Cunningham's Avatar
You could do a Holley 350 or 500 swap for under $150 if I'm thinking right and you can get rid of a lot of vacuum lines I did mine with a Holley 500 carb Holley pressure regulator and a electric fuel pump
daddio
08-09-2015 07:17 PM
tomczaksdiesel
07-26-2015 10:35 PM
Yota.Jay
07-23-2015 08:08 PM
Quick Reply: 92 22re to carb???????
