welding front diff
welding front diff
On my 83 Toyota I am rebuilding my front axle knuckles I have my axles out so I was going to pull my carrier out and weld my front diff will I need to remove the ring gear to weld the spider gears and if I remove the ring gear will that change any of my preload or backlash.
You do not have to pull the carrier/ring gear to weld the diff.
If your going to be wheeling it, the best way to weld the diff is to crank the heat up and weld the spider gears TO the carrier, as well as each other. Or if you dont want to weld to the carrier, cut 2 plates and weld them into the spider gears like below. Try not to cook the bearing too much. You can wrap tinfoil around the ringgear and shove some down into the pinon gear to stop weld splatter from getting on the gears.
(I found both of these pictures on google, not mine)
With plate:
A little ugly, but heres welded to the carrier
With plate:
If your going to be wheeling it, the best way to weld the diff is to crank the heat up and weld the spider gears TO the carrier, as well as each other. Or if you dont want to weld to the carrier, cut 2 plates and seld them into the spider gears like below. Try not to cook the bearing too much. You can wrap tinfoil around the ringgear and shove some down into the pinon gear to stop weld splatter from getting on the gears.
With plate:
With plate:
that's what I wanted to see if I could even get the welder in there
FS[GreatLakes]: Toyota collection part out
88sasturbotoy
08-11-2015 01:56 AM
FS[GreatLakes]: Wanted: 4.88 front diff, rear 8'' 4.88
jaretstuff
08-04-2015 02:08 PM
Steven.m.paulk
07-24-2015 01:44 PM
scottyg486
07-19-2015 05:34 PM
TokyoD23
07-12-2015 06:01 AM
