Fitting 33x12.50s or bust!
Well on an otherwise stock suspension besides very small tbar crank the 33s are goign on tomorrow. Will not leave the garage until i can stuff the tire without rubbing Haha wish me luck, pics to follow of cousre
tires are on, they barely rub even while being stuffed with a minimum fender lining trim. Very happy with the result, should have done this sooner and not thought I ever needed to lift 4+ inches. Pics will be up tomorrow
eh... I had 33x12.5x15 on my '91 4Runner with no lift and a saggy butt.... so does dublin. Anway, I had them on 15x8's with 3.75" BS. All I had to do was hammer the pinch weld down.
Sure, you can stuff em' in there. But, If there's no room for them to move, you won't be able to make use the suspension. Some kind of lift is definitely a good idea.
Hell, I can fit some 27" BFG MT's under my cellica.....but it won't turn.
I am putting the 1.5 inch BJ spacer in the front. I already have the extended shackel in the rear. I am sure I can fit 33 inch tires just not sure about 12.50 width.
Keep us posted an would like to see the pictures.
Thanks
Thanks
Sorry I'm at work right now but I did post up a trail report with my truck in there. The title was Tuttle Creek something or other.
edit here it is: https://www.yotatech.com/forums/f100/tuttle-creek-orvp-randolph-kansas-pics-81710/
chuckd83
09-14-2015 03:20 PM
anniesball
09-05-2015 08:45 AM
