2wd to 4wd and stock height to Tacoma height?
Hey folks, hopefully you guys can answer this. Getting tough finding a decent Tacoma for a decent price, so I'm thinking about finding a 6 cylinder 2wd for a good price and simply putting the parts on myself, or paying someone else if it's within budget.
Price differences are ridiculous here, so I'd have 2-3k to invest into the 2.
I don't need good suspension, just suspension that works and isn't black market quality. I may even be able to put in a set of 3" strut spacers (assuming 3" is the difference). I know the suspension won't be great, but as long as it isn't terrible on the road, then that's fine with me.
The 4wd part of it will probably have to be from an original Tacoma, unless I guess there are other vehicles that use the same parts. I hear you may need the 4wd transmission as well? Any parts required, or links to kits that include everything needed would be great, just so I can get an idea.
Anyone done a project like these before? How much did you end up spending?
Anyone else got a good idea of the cost and labor? I've swapped motors + transmissions before but haven't messed with suspension too much, if I feel anything is to "intense" I may pay someone to do it, if it's in the budget.
For some reason I feel like it might be easier/cheaper to SAS the 2wd than to try swapping in IFS 4wd. It would be like doing a normal SAS but having to add a driveshaft and, t-case, and probably 4wd transmission.
EDIT: Nevermind, I think I got ya. It's more than just adding a SAS, it's adding those additional parts too. So IFS is the standard route and it's a huge PITA?
Also, are you thinking about finding a pre-runner or a regular 2wd?
I do have something similar asking if the height is different. This one is recognizing that the two are completely different and the project required to change it.
If you can change the other threads title to this one, that'll be the correct subject, and we can delete this one - or I can add the text from this original post. I know we started to talk about these things, but it started to stray from the subject and there wasn't anymore discussion about it.
Up to you, sir.
Up to you, sir.
Flying91
45
04-11-2024 04:39 PM
djpg2000
11-11-2020 04:56 AM
TokyoD23
07-12-2015 06:01 AM
